AEM EMS 2 & ECU Patch/Extension for Gen 7 Civic
เริ่มโดย iYakumo, 2012-01-17, 15:31:07
ใครอยากแรงเชิญ ทางนี้เลยนะครับ
AEM PLUG & PLAY ENGINE MANAGEMENT SYSTEM – SERIES 2
AEM's Plug & Play Engine Management System (EMS) Series 2 is a complete engine control system that plugs into the factory harness and uses the factory sensors. This means you do not need to replace any parts of the harness or sensors, just plug the EMS into the harness and begin tuning! The Series 2 EMS allows you to control every aspect of your engine. From VTEC to rev limit, timing, adding different sized injectors, boost control, nitrous injection, even anti-lag and individual cylinder fuel and timing trims, the Series 2 EMS gives you total control from an easy to use interface.
•Plugs directly into the factory harness. No rewiring necessary.
•Maps can be password protected by the tuner to prevent unauthorized usage or sharing.
•Tune using new USB communication port or serial port.
•New smaller enclosure for reduced physical size.
•1MB of internal data logging
•Up to 12 peak and hold injector drivers.
•Up to 8 direct-fire coil outputs.
•Works with all AEM gauges.
Civic   2001-2001    - Engine Management System - Plug & Play - Series 2    - DX   1.7L 1668cc L4 D17A1   Manual Transmission
Civic   2002-2003    - Engine Management System - Plug & Play - Series 2    - DX   1.7L 1700cc L4 D17A1   Manual Transmission
Civic   2004-2004    - Engine Management System - Plug & Play - Series 2    - DX   1.7L 1700cc L4 D17A1   Manual Transmission
Civic   2005-2005    - Engine Management System - Plug & Play - Series 2    - DX   1.7L 1668cc L4 D17A1   Manual Transmission
Civic   2001-2001    - Engine Management System - Plug & Play - Series 2    - EX   1.7L 1668cc L4 D17A2   Manual Transmission
Civic   2002-2004    - Engine Management System - Plug & Play - Series 2    - EX   1.7L 1700cc L4 D17A2   Manual Transmission
Civic   2005-2005    - Engine Management System - Plug & Play - Series 2    - EX   1.7L 1668cc L4 D17A2   Manual Transmission
Civic   2001-2001    - Engine Management System - Plug & Play - Series 2    - LX   1.7L 1668cc L4 D17A1   Manual Transmission
Civic   2002-2003    - Engine Management System - Plug & Play - Series 2    - LX   1.7L 1700cc L4 D17A1   Manual Transmission
Civic   2004-2004    - Engine Management System - Plug & Play - Series 2    - LX   1.7L 1700cc L4 D17A1   Manual Transmission
Civic   2005-2005    - Engine Management System - Plug & Play - Series 2    - LX   1.7L 1668cc L4 D17A1   Manual Transmission
Civic   2002-2005    - Engine Management System - Plug & Play - Series 2    - Si   2.0L 1998cc L4 K20A3
Civic   2004-2004    - Engine Management System - Plug & Play - Series 2    - Value Package   1.7L 1700cc L4 D17A1   Manual Transmission
Civic   2005-2005    - Engine Management System - Plug & Play - Series 2    - Value Package   1.7L 1668cc L4 D17A1   Manual Transmission
AEM ECU PATCH/EXTENSION HARNESS
AEM's ECU Patch/Extension Harnesses work with most engine management systems and allow you to install turbo timers, data loggers and other ancillary electronics without having to cut and splice into your factory wiring harness.
Civic   2001-2001    - ECU Patch/Extension Harness    - DX   1.7L/1668ccL4 [D17A1]   Automatic
Civic   2001-2001    - ECU Patch/Extension Harness    - DX   1.7L/1668ccL4 [D17A1]   Manual
Civic   2002-2003    - ECU Patch/Extension Harness    - DX   1.7L/1700ccL4 [D17A1]   Automatic
Civic   2002-2003    - ECU Patch/Extension Harness    - DX   1.7L/1700ccL4 [D17A1]   Manual
Civic   2004-2004    - ECU Patch/Extension Harness    - DX   1.7L/1700ccL4 [D17A1]   Automatic
Civic   2004-2004    - ECU Patch/Extension Harness    - DX   1.7L/1700ccL4 [D17A1]   Manual
Civic   2005-2005    - ECU Patch/Extension Harness    - DX   1.7L/1668ccL4 [D17A1]   Automatic
Civic   2005-2005    - ECU Patch/Extension Harness    - DX   1.7L/1668ccL4 [D17A1]   Manual
Civic   2001-2001    - ECU Patch/Extension Harness    - EX   1.7L/1668ccL4 [D17A2]   Automatic
Civic   2001-2001    - ECU Patch/Extension Harness    - EX   1.7L/1668ccL4 [D17A2]   Manual
Civic   2002-2004    - ECU Patch/Extension Harness    - EX   1.7L/1700ccL4 [D17A2]   Automatic
Civic   2002-2004    - ECU Patch/Extension Harness    - EX   1.7L/1700ccL4 [D17A2]   Manual
Civic   2005-2005    - ECU Patch/Extension Harness    - EX   1.7L/1668ccL4 [D17A2]   Automatic
Civic   2005-2005    - ECU Patch/Extension Harness    - EX   1.7L/1668ccL4 [D17A2]   Manual
Civic   2001-2001    - ECU Patch/Extension Harness    - HX   1.7L/1668ccL4 [D17A6]   Manual
Civic   2002-2003    - ECU Patch/Extension Harness    - HX   1.7L/1700ccL4 [D17A6]   Manual
Civic   2004-2004    - ECU Patch/Extension Harness    - HX   1.7L/1700ccL4 [D17A6]   Manual
Civic   2005-2005    - ECU Patch/Extension Harness    - HX   1.7L/1668ccL4 [D17A6]   Manual
Civic   2001-2001    - ECU Patch/Extension Harness    - LX   1.7L/1668ccL4 [D17A1]   Automatic
Civic   2001-2001    - ECU Patch/Extension Harness    - LX   1.7L/1668ccL4 [D17A1]   Manual
Civic   2002-2003    - ECU Patch/Extension Harness    - LX   1.7L/1700ccL4 [D17A1]   Automatic
Civic   2002-2003    - ECU Patch/Extension Harness    - LX   1.7L/1700ccL4 [D17A1]   Manual
Civic   2004-2004    - ECU Patch/Extension Harness    - LX   1.7L/1700ccL4 [D17A1]   Automatic
Civic   2004-2004    - ECU Patch/Extension Harness    - LX   1.7L/1700ccL4 [D17A1]   Manual
Civic   2005-2005    - ECU Patch/Extension Harness    - LX   1.7L/1668ccL4 [D17A1]   Automatic
Civic   2005-2005    - ECU Patch/Extension Harness    - LX   1.7L/1668ccL4 [D17A1]   Manual
Civic   2002-2005    - ECU Patch/Extension Harness    - Si   2.0L/1998ccL4 [K20A3]
Civic   2004-2004    - ECU Patch/Extension Harness    - Value Package   1.7L/1700ccL4 [D17A1]   Automatic
Civic   2004-2004    - ECU Patch/Extension Harness    - Value Package   1.7L/1700ccL4 [D17A1]   Manual
Civic   2005-2005    - ECU Patch/Extension Harness    - Value Package   1.7L/1668ccL4 [D17A1]   Automatic
Civic   2005-2005    - ECU Patch/Extension Harness    - Value Package   1.7L/1668ccL4 [D17A1]   Manual
อสูรร้าย
หนึ่งใน To Do List ของท่านยม   ;D
Unlock The Power
